Subwoofers cutting in and out
  • 3
phatcat600
yeah my name is stupid
I am running two Q12's in 2.2 cubes @ 32hz each, powered by a 2000 watt Hifonics (yeah, I know.) amp
Everything was fine for the last 10 months, now all of a sudden at higher volumes the subs cut in and out. The amp is not going into protect, the subs will just boom a few times and then barely do anything for 5-10 seconds, then boom again.
My wiring is all still connected. Any ideas?
Edit: The ground wire looks a little green on one side like it is corroded, but it it should definitely still be a good enough connection. Wouldn't a bad ground make it go into protect anyway?
Are these single or dual voice coil subs. Sounds like a vc may b cutting out but id recheck all wiring and grounds,sub wiring, tben check the vc with a dmm for the proper ohm reading
Q's are dual voice coil. They are getting pretty old, 2009 model; a voice coil issue scares me. Checking the sub wiring inside the box would be the last thing I ever check, they've been hooked up for 3 years and everything inside is very sturdy.
How do burnt voice coils work? I thought once they were done they were done...but they will play consistently at middle volumes without issue. Anyone else have anything to add?
Check all wires first. You may b to check the vcs for proper impedance from the hookup at the box if you know how they where wired ie d2 to 4 or .5 ohm or d4 wired to1 or 8 ohm ect. If one vc is way off check the wire first but may b vc u will normally get an ohm reading on the meter if u put one lead on pos one on neg a burnt out coil will usually show ol on the meter.
I don't remember what impedence the subs were, but I know I had them correct to be wired to 1 ohm. There are two sets of terminals and they are dual voice coil subs. Both sets of terminals test out to 1 ohm. Does that rule out a burnt voil?
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
568
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
12
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
phatcat600
phatcat600
Dowagiac, MI
Robert 2001
Decebal
    Jun 10, 2024
