subwoofers + truck
Vagomire
I need to know the best way to make subwoofers loud in a truck. I know that trucks have a very small airspace and they don't have a trunk for the sound to reverberate off of, so how to do you make subwoofers louder in a truck?
The truck happens to be a 1995 Chevy extended cab, so the seats can be taken out.
I just want to know what type of box design, if any, can make the subwoofers seem louder in a small airspace. Do you buy small subwoofers or big ones? Any help is appriciated.
Thanks, Joe.
build a box under the seats, 3 or 4 sundown Sa-8's, dont worry about size its about sound any douche can roll around with an 18... run about 500rms each sub, not that you have to use it but youll have room to play, run ported box with good air space and youll be loud, so youll need 1500-2000 watt amp. can be found used here in classieds for about 200-400 depending on brand/quality. Sa-8's are around 100 a piece.
If it were me, I would remove the back seat and build a sixth order bandpass. Plot one with about a 10db peak between 40 and 50 hz. Find 2 subs with FS in this peak. Then power to their limits and rape.
Some people like to listen to music too //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
He didn't say anything about music //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I guess you were the only one born without common sense. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
It's common sense to NOT answer the question as it was asked? How does that make you the smart one. Don't be mad because you don't know how to design or build a 6th order. faggot
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
552
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
12
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Vagomire
Vagomire
Rockford, IL
hatedonmostly
