Subwoofers Won't Work on Working Amplifier? HELP
  • 4
Thampy16
I have two alpine type r 12 in dual voice coil 4 ohm subs that I haven't been able to listen to. I'm too stubborn to take it to an audio shop, and the closest one is miles away. So I was wondering if someone could help me out. I ran my multimeter on the outer terminals and got a 2.4 ohm reading (which is what I wanted) and my continuity test also came back with a resistance of a single digit 2! I'm very flustered and hooked them up to my friends amp that I know works and is very much capable of powering my subs. Please help!
---------- Post added at 09:35 PM ---------- Previous post was at 09:34 PM ----------
I can post photos and take a sub out of box if need be
SO both coils read fine, but it won't play? Can you push on the cone and move it, or is the sub seized up?
If the coils read fine, the amp works, the sub moves when you push on it, and the motor is magnetized (T Fade got a sub one time that wasn't magnetized //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif but that's rare) there shouldn't be an issue.
Is your friend's amp the only amp you've tried it on, or do you have one you've tried it on, too?
If you have an amp of your own that you've tried it on, can you try any other sub(s) on your amp?
Troubleshooting anything is often all about isolating variables and swapping things out until your solution is found
A 4 ohm sub shouldn't read 2.4 ohms....unless the batteries in your dmm are going bad giving you bad readings or tested them wrong with your dmm. Not saying you did but is possible. It should be something closer to 3.8 or so. I have a dual 2 ohm sub and I got 1.7 from my dmm.
You can do a simple test with any size battery to see if the sub is good by hooking up speaker wires from the sub to the battery. the subs cone should move outward a little. That means it's good. If it moves inward, reverse the polarity.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
502
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
12
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Thampy16
Thampy16
Maysville, KY
Boomin_tahoe
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
