Suggestions for 8"-10" Midwoofer
  • 6
got_focus?
Skeet Skeet Skeet
1,594
Loveland, CO
Current setup -
Memphis Big Belle amplifier
Kenwood DDX7017
ID HLCD Horns
AudioControl DQXS
Sundown e8 (x2) in a transmission line box (soon to be sa-8's)
Looking for something that will keep up with the horns, but offer superb quality at high volumes. Seeking incredible midbass as well. I will be using a 8"-10" driver in my door, fiberglassed obviously, using the door as the enclosure. The doors are sealed except for the rubber flap on top where the window meets as well as the vents on the bottom side of the door to let water out.
I was thinking something along these lines -
Parts-Express.com:Morel CAW 938 9" Cast Frame Woofer | caw938 mw-265 mw-266 mw265 mw 265 6 inch woofer mid woofer midbass 6" woofer poly cone shielded woofer
But open to all suggestions!
No driver linked in this thread will deliver "amazing midbass" or even being to keep up with a set of horns. Even if we give the horns 1 watt of power those 10's aren't going to keep up going full bore.... You need a high effeciency mid. Look at your effeciency spec and shoot for 94db/1w/1m at least. Xmax isn't a big deal since 10's have alot more cone area than a 6.5 or an 8. Just 4mm will get you down to 80hz with a steep slope.
Anyway if your budget is around the morel of 140ish per speaker
B&C 10NDL64
or Faitel Pro 10PR300
The B&C is probably a little nicer, it also cost a bit more. Both are neo which will keep the back end size down, which help since your trying to cram a pro audio 10 into a door....
10
897
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
663
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
895
got_focus?
Skeet Skeet Skeet
got_focus?
Loveland, CO
Horsemanwill
