Suggestions please - 6.5" comps in the $700-$1300 range.
I decided to go with a set of Earthquake "screamer" tweeters. For my application/budget they are a better fit. Also, I couldn't pass up the great price that thelow had for them. I purchased an ARC audio amp to power them - http://www.woofersetc.com/p6856/FD-2200--ARC-Audio-2-Channel-370-Watt-Amplifier.htm great deal on a nice amp.
I also purchased the set of morel supreme mids. I'm going to power them with my JL 300/2.
To flipx99 who suggested the scan mids: they wouldn't fit in my doors. I'm not chopping my doors under any circumstances.
For the install, I purchased stinger pro series interconnects and kukonceptz karma speaker wire. I have some distro blocks coming in the mail as well. 4ga in 8ga out to split my power and ground connection between my two front stage amps. The 8ga wires will travel less than 12", so I'm not worried about them.
Any suggestions on material to make the plates for the woofers? I've seen some buzz about cedar, is that a proper material for door plates? Also, how does it compare with a thin (maybe 1/2" or 1/4") MDF plate?
One other question about DIY plates - what tool should I use to cut the hole? My jigsaw is old, shoddy, and inaccurate. I don't own a router; should I look for a drill bit that can cut a hole large enough for these woofers?
use 1/2" mdf. some people use the original baffle and trace that to make the new baffle. If it's too late for that, use construction paper and a crayon to make a rubbing of the baffle area maybe and go from there. You will need to coat the baffle with something to make it waterproof.
jig-wise for making circles, I bought the two pack of jasper jigs from parts express and a plunge router THAT FITS THE JIG.(no harbor freight crap)
use 1/2" mdf. some people use the original baffle and trace that to make the new baffle. If it's too late for that, use construction paper and a crayon to make a rubbing of the baffle area maybe and go from there. You will need to coat the baffle with something to make it waterproof.jig-wise for making circles, I bought the two pack of jasper jigs from parts express and a plunge router THAT FITS THE JIG.(no harbor freight crap)
He doesn't have a router so the jasper jig doesn't help.
I think there are people that make rings for next to nothing.
Does anyone know if a major hardware store -such as loews or home depot- would cut the 1/2" MDF for me if I brought them an outline?
Obviously I expect to pay them for the service, but I don't know if they offer that service at all. I'm going to call my local store to ask, but has anyone ever heard of something like that?
No, they do not offer routing services. The panel saw only makes rip cuts.
A local cabinet/molding shop may do it for you.
hm. I don't know any of those haha. I could just ask the local car audio shop to do them, they did a great job with the fiberglass box they built for me. The only worry with that is they work *very* slowly. Lol.
I get antsy once I get a new toy... I want to play with it immediately like a little kid.
Why not just get a blade for your jigsaw and a large drill bit.. Drill a large hole in the center to insert the blade and cut the circle? Do the same thing for the outside also.
Local shops should do this as well. If it didn't cost any extra, I'd have them flush mount it in the ring.
I think I'm going to do that, as a matter of fact. I think they'll enjoy taking a look at the drivers too - they only sell a handful of mainstream brands, but it was clear upon deeper conversation that they are well versed in more high-end drivers.
Holy cow. My shipment came in from KnuKonceptz today. I have never seen such beefy speaker wire in my entire life. I ordered the karma wires, twisted pair 10ga. The wire is extremely impressive in person.
I think the 10ga *might* be overkill for my front stage lol. I suppose it's better to have overkill than not enough though.
Kinda sad to see Morel Supreme mids paired with Earthquake "screamer" tweeters but okay. And 3-way front stage in a Mustang is a lot of work that the OP probably wouldn't be up to. I'm not. I like my simple 2-way FS and sub set-up for now. What is your head unit?
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
855
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
631
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
11
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
854
WheresTheButta
WheresTheButta
Cranford, NJ
WheresTheButta
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
