Sundown SAZ 2500D like new!
Traks
Sundown SAZ 2500D
9/10 few scratches around the feet from mountin
$500 + shipping
SPECIFICATIONS:
•Digital Class-D Linkable Mono Block Amplifier
•Double Sided Through Hole Epoxy PCB
•1 Ohm Stability
•Daisy-Chain Through Output RCA
•Efficiency : 86% @ 4 ohm, at 100Hz
•24dB/Oct Variable Crossover
•Multi-Way Protection Circuitry
•(Thermal/Over Current/Speaker Short/Speaker DC Protection)
•RCA Line Input and Master Output
•24dB Octave Crossover Slope
•24dB Octave Variable Subsonic Crossover Slope
•Variable Bass Boost
•Variable Low Pass Filter
•Variable Phase Shift
•Zero(0) Gauge Power Supply Connectors
•Tested Voltage & THD : 14.4V & Less than 1% THD
•Operating Voltage : DC 10V~18V
•Wired Remote Controller
Rated power output
----RMS power, 2 ohm linkable/dual mono
5000W x 1CH
----RMS power, 1 ohm mono
2500W x 1CH
----RMS power, 2 ohm mono
1200W x 1CH
----RMS power, 4 ohm mono
600W x 1CH
Signal to Noise Ratio
Well then you must not need it gone that bad haha... Wish you where taking trades and Id consider it...
Nope I dont need it gone at all. If it doesnt sell it will go in my wifes car before I give it away.
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
608
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
3K
Traks
Traks
Mattoon,IL
boomzabit
