Sundown X-15 Question
clemson27
#AintLoud
17
Indiana
Currently have a Sundown X-15 v1 dual 2 ohm in a 4 cu ft box tuned to 32hz powered by an Audiopipe Apmi 2k wired at 1ohm. My question is where should I set the Subsonic filter, and the Low pass filter at? Also, I have an oscilloscope to tune the amp, but Im not sure exactly how to tune it since I have a Rockford Fosgate Balanced Line Driver that has a gain knob on it too. Any help would be appreciated.
Put the oscope to the head unit first on a 40hz sine wave. raise the head unit volume high up the max it can go before distorting. Then go to the line driver, raise it to the max it can go without distorting. Then go to the amp and up the gain. If its already distorting with the gain at 0 then you need to lower your line driver until its a clean wave at 0 gain.
Subsonic at around 25hrtz, low pass usually between 80 and 100hrtz.
Would love to hear what you come up with. My speakers are clipping like you wouldn't believe at loud volumes. Running a x series 12 in my Mustang with a Skar 75.4 which I believe is a POS but im not sure
Then your over working your skar 4ch... turn the gain down so your not clipping
Well my Hx2 project is on hold while I wait for a custom voice coil lol. Now that I have a pretty decent amp I have some options. Never ran a 15...
587
10
clemson27
#AintLoud
clemson27
Indiana
Tastypandas
    May 31, 2024
    May 24, 2024
