Sundown zv4 15 box design
  • 4
Hi I'm building my first box. I was looking for help in design and what material to you use. It is one zv4 15 in a 99 Suburban. So i have plentry of room. Any help would be great.
Your are gonna want to use 3/4 inch MDF (medium density fiber) board, They sell 4x4 sheets at menards. For the design, use This. adjust the port to your desired tuning frequency and it will spit out what dimensions to use, check the specs for your sub to make sure the chamber has enough cubic ft for it sound good. Your tuning frequency can be anywhere from 25-40 Hz for most bass music, closer to 25 Hz if you like to listen to songs with very low bass, closer to 40 if you listen to songs with high bass tones like EDM or rap.
Ported or sealed? Either way, you could just follow sundowns recommened box design.
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
503
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
3K
turndownforwhat
turndownforwhat
Fremont Ca
Justin braaapp
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
