Box design help - 04 F150
  • 2
09Alti
Hey guys - I'm helping a friend build a small system in his truck and we need a design for a box. Building it won't be a problem, we just don't know the dimensions we need.
The truck is a 2004 Ford F150 Heritage (2dr, standard cab)
The sub is a Sundown SA10 (D4's) that will be getting about 1k from an Alpine amp (not sure the model)
Hoping to tune to 32-35hz
We're leaving towards something ported, with the port facing either up, or at the passenger side of the truck but if you guys have other options I'd like to hear them.
Thanks!
Thanks!
try This. Very easy to use if you know your tuning frequency.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
742
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
In the meantime you could stuff that port hole with a blanket or some pillows and it would probably sound better, if you want to listen to some...
12
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
535
09Alti
09Alti
Charleston, SC
dubstepper1000
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
