tantric HDD 15's repair Q
I just tested the coil in Q as far back on the tinsels as i could, and i got .7 out of it. There is no coil rub.. Maby a crude dust cap removal and i could do a temp fix?
Pretty useless now since that company no longer exists. Unless your lucky enough to find a recone kit for that sub somewhere i.e. ebay, CL, Offerup, etc.
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
I was tempted to send an offer, but felt the 100 was fair for it since it was like new still. You still did good on it though.
ptcruiser07
ptcruiser07
TX
ptcruiser07
