inteva6184
Hey just wanted to see what you guys thought my issue and fix is. I have a 2011 f-150 with what I believe to be a 200 amp alternator. I did the big 3 with 0 gauge wire and I ran 0 gauge from the battery to the amp and 0 gauge to my prepped ground. The issue is I am getting some serious voltage drop I haven't even checked at the amp yet but my bs cigarette lighter meter shows me dropping quickly into the 12's and also occasionally into a 11.6 if I let certain songs run at full tilt for a minute. I wouldn't be to worried except occasionally my ppi 900.4 shuts down which tells me I am seeing way to much voltage drop at the amp. I went around checking my connections and they all feel solid so basically before I go nuts I wanted to know is the a common drop for a 5000 watts rms amp? Am i going to need a bigger alt or better battery or do I have another issue? Thanks
