Teardown Alpine CDA-7998 faceplate to replace ribbon cable instrux...
  • 4
Agent Cooper
CarAudio.com Newbie
Diane,
Trying to teardown an Alpine CDA-7998 to replace both ribbon cables, in hopes of resuscitating the no-display OELD-401. YES, we all know it's A Long Shot, but We must exhaust all options before sacking the unit for parts, hoping to Merge it with an existing useable OELD-401. Bleh.
PROPS to User=Mobhit for his comments, insight and pictures over on https://www.caraudio.com/threads/repairing-cda-7897.572603/#post-8327342 .
Excellent work, and I appreciate the fact that the photos are still sitting in that Photobucket (or on the Crutchfield Server) after all this time. Was a great help in starting this teardown.
[Only thing that was missed in commentary was the fact that you have to pinch the white standoff next to the ribbon cable with dinky pliers to get it to release the board beneath the CD cradle.]
Anyway, after some coffee, on to the task at hand....
Using the teardown instrux at link above, I was easily able to replace the first ribbon cable, PN 84T55484Y01: https://www.pacparts.com/part.cfm?part_no=84T55484Y01&mfg=Alpine
Item 23 on page 45 of the Service Manual. Thanks again to User=Mobhit.
Replacing the ribbon cable connecting the lower board to the faceplate (PN 84T55483Y01: https://www.pacparts.com/part.cfm?part_no=84T55483Y01&mfg=Alpine) appears to be A Different Matter Entirely, ie "The Owls Are Not What They Seem".
To begin...after following User=Mobhit 's teardown:
1) Undo the slide locks on the bottom circuit board. See picture, with black slide lock edges circled (poorly) in black. Ribbon cable flops right out.
26587
2) The Service Manual for the CDA-7998R shows an exploded view of the faceplate which does NOT correspond to the physical specs on the CDA-7998. It indicates there are two screws at the upper right/left rear of the faceplate, and these are NOT present on the CDA-7998. See page 45 of Service Manual, item 39, and see picture with area in question circled (poorly) in red. Note also there is a spudger-style orifice in the vicinity as well, but I don't want to go at that until hearing back from more experienced Members. This may be The Key to obtaining access to the board contained within the faceplate, but I don't want to snap anything :/
26588
3) I don't think you can just rip the ribbon cable out of it's socket on the back of the faceplate. See picture (above), with area in question circled (poorly) in red. These sorts of connections typically have slide locks on them, see 1) above.
4) See picture, I've circled (poorly) a section of that side of the faceplate....this is a PIN, and will not come out of the side of the faceplate, so I'm at a loss for how to completely remove the faceplate for ease of further dismantling. [Edit: note that screw beneath this pin has been removed. Remove this screw (and the one on the other side) before attempting to spudger in later posts...]
26589
So, that's it, end of pseudo-tutorial-presented-as-a-question.
I'm stuck trying to remove the end of the ribbon cable from the back of the faceplate without causing chaos.
Any insight or guidance from The Community appreciated.
We'll turn this into a tutorial at some point :)
Oh, Diane, I almost forgot. I've got to find out how to fix this head unit. They're really something special.
HAHAHA
Well, Diane, much time has passed...with little to show on this project.
As this unit is pretty much a throw-out without a usable face, it's Owner and I decided to try just pulling out the ribbon cable in question...which, as expected, didn't go well :/
You can see the edge of the white reinforcement strip from the ribbon cable stuck in the faceplate orifice...
Diane, thankfully we have the replacement part in hand...
Just (still) don't have a clue how to open the faceplate
Quoted from previous: "Any insight or guidance from The Community appreciated."
Hmmmm......Spudger was indeed the key.
Insert Spudger into orifices at top back of faceplate, pry a tad to achieve separation....
Note what happens to sides of faceplate, including what we thought was a locked-in pin...
Pin location circled, as well as spring arm that will need to be re-inserted into proper place on side...
[Edit: note that screws have been removed per edited directions in previous steps. Spunding will NOT unlock faceplate without removing these screws...]
Running the spudger along the back bottom of the faceplate will eventually unlock the faceplate from the mechanism...
Retention clips / ramps are circled (poorly, a recurring theme here)...
Try to change the complete face plate 7897
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
204
This weekend I will be taking actual pictures for other sites. So grab it before its gone
6
622
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
5
593
Agent Cooper
CarAudio.com Newbie
Agent Cooper
San Marcos, CA, USA
Bradley Frank
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
