TFT Monitor - how do you connect it?
  • 2
I recently bought a truck which came with a back up camera and monitor. Both were attached but wiring was not connected. I can't figure out how to connect the monitor. There is only one cable coming out of it. Is this cable some how supposed to be used for power and video in? Do I need some kind of adapter to power it through the cigarette lighter?
I have attached a picture.
Thanks!
Shawn
Thanks!
Shawn
youre either missing a piece or its a bespoke monitor built specifically to fit into one device. That round cable on the end is called a DIN cable and it likely has power, ground, remote turn on and either a composite or vga input. You might have to either chop the end of that cable off and solder on connections to manually connect it to the cam or find the missing piece that it looks like it needs
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
374
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
529
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
3K
Shawnamillion
Shawnamillion
toronto, canada
youdoofus
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
