The Complete Wiring Kits, Stage 1, Stage 2, Stage 3
  • 2
GPcarAudio.com
Pro Seller
Supporting Vendor
1,062
Missouri
**The Complete: 1/0 AWG Stage 1 Wiring Kit - gp car audio
**The Complete: 2/0 AWG Stage 1 Wiring Kit - gp car audio
*SEE BELOW FOR WIRING DIAGRAM*
Get the job done quick and easy with TRUE 1/0 AWG The Complete Kit. Featuring the GP's Merica NO BS PURE COPPER Wire. Made in the U.S.A.
This all in one package deal includes:
1) Set of GP SAE Machined Terminals: This allows for quick and easy wiring under the hood.
1) Big 3 Kit
1) Amp Kit
Here is the list of items included in The Complete Kit
*One Pair GP SAE Machined Terminals
*Big 3 Kit Includes:
2) 1/0 AWG 4 FOOT GROUNDS
1) 1/0 AWG 4 FOOT POWER
6) 1/0 AWG Pure Copper LUGS
6) GP 'MERICA HEAT SHRINK
PRE- 16 TON HYDRAULIC CRIMPED WITH 1/0 PURE COPPER LUGS WITH 3/8th's HOLE ON ONE END, AND GP HEAT SHRINKED
*Amp Kit Includes"
17 feet 1/0 AWG OFHC Power wire (pre hydrualic crimped lug on one end with heat shrink)
3 Feet 1/0 AWG OFHC Ground Wire (pre hydrualic crimped lug on one end with heat shrink)
17 feet 14 AWG remote wire
1) GP 24k ANL Fuse
*The Complete Advanced: 1/0 AWG Stage 2 Wiring Kit - gp car audio
*The Complete Advanced: 2/0 AWG Stage 2 Wiring Kit - gp car audio
This advanced kit is prepared for those running a secondary battery (battery not included) and contains ALL necessary wiring, lugs, and fuse blocks to setup an advanced electrical setup. This kit also comes equipped with a full dual input kit.
Get the job done quick and easy with TRUE 1/0 AWG The Complete Advanced Kit. Featuring the GP's Merica NO BS PURE COPPER Wire. All contents are Made in the U.S.A.
*The Difference between this kit, and the standard "THE COMPLETE KIT" is the addition of an extra fuse for your main power run to isolate the main power wire from the use of a secondary battery, an added DUAL INPUT KIT with fusing, and an extra ground. (See Wiring Diagram below)
1) Big 3 Kit
1) Amp Kit
1) Dual Input Kit with Fusing
1) Extra 3ft Ground
1) Extra fuse for main power run with necessary lugs and shrink
Here is the list of items included in The Complete Advanced Kit
*Amp Kit Includes:
1) GP 24k ANL Fuse block
1) Fuse
Dual Input Kit (with fusing) Includes:
1) Pair of GP machined Dual Inputs (offset vertical)
2) 3 foot 1/0 AWG GP Merica PURE COPPER Power Wires (hydraulic crimped and heat shrink lugs on one end)
2) 3 foot 1/0 AWG GP Merica PURE COPPER Ground Wires (hydraulic crimped and heat shrink lugs on one end)
2) GP ANL FUSE BLOCKS
2) FUSES
4) Extra Lugs and Shrink
*Extra
1) Extra 1/0 AWG pre terminated 3ft Ground is included (hydraulic crimped and heat shrink)
1) Extra fuse and fuse block, with lugs and shrink
*Note We suggest fusing the main power wire at the wires rated amperage, GP 1/0= 350 amp, GP 2/0= 400 Amp, and the amplifier manufacturers suggested fusing on the dual input runs, EXAMPLE: If the amplifier manufacturer suggests a 300 amp fuse, you will want to run 150 amp fuses on the dual inputs.
*The Complete Elite: 1/0 AWG Stage 3 Wiring Kit - gp car audio
*The Complete Elite: 2/0 AWG Stage 3 Wiring Kit - gp car audio
Wattage Suggestion: 4,000 to 8,000 Watts RMS
This Elite kit is prepared for those running a secondary battery/ bank, (battery not included) and contains ALL necessary wiring, lugs, and fuse blocks to setup an Elite electrical setup.
Get the job done quick and easy with TRUE 1/0 AWG The Complete Elite Kit. Featuring the GP's Merica NO BS PURE COPPER Wire. Made in the U.S.A.
*See Wiring Diagram below
This kit has a ton of items!
Here is a simplified view/ pack list of all the items included in The Complete Advanced kit.
THE COMPLETE ELITE PACK LIST
QTY)
1) Pair SAE TERMINALS (be sure all hardware included)
2) Pairs of DUAL INPUTS
8) Fuse Blocks
8) Fuses (per size selected)
16) LUGS AND POWER COLOR HEAT SHRINKS (in eveloped labeled fuse block lugs and shrink)
2) 17ft POWER COLOR wire Lug crimped and shrinked on both ends
4) 3 ft GROUND COLOR wire lugs crimped and shrinked on both ends of each wire
2) 17ft REMOTE WIRE
2) 4ft POWER COLOR WIRE, lug crimped on one end of each wire
4) 4ft GROUND COLOR WIRE, lug crimped on one end of each wire
6) Lugs and heat shrink, 2 power color 4 ground color, in envelope labeled big 3
4) 3ft POWER COLOR wire - lug crimped on one end of each wire
4) 3ft GROUND COLOR wire- Lug crimped on one end of each wire
Here is a 2/0 AWG Complete Elite Stage 3 wiring kit that just shipped out, the included- 2 pairs of dual inputs, are not in this photo. This is almost 100ft of pre prepped wire.
Hand made Ultra HiFi RCA's are available at a discounted price with all kits.
GP Audio's Ultra HiFi RCA's
Hand made in the U.S.A.
We have teamed up with DH LABs to create the Ultimate HiFi RCA for the car audio world. These new connectors feature a machined one piece body and a pure copper center pin. The center pin material is made in the U.S.A. to ensure the highest quality and is composed of 99.5% pure copper, with a conductivity rating that is at the top of the industry.
The cable is a 99.99% PURE COPPER quad conductor, heavily insulated with stranded cotton wrapped with a pure copper tinned braided shield. These two top level components are then soldiered with a blend of silver and copper quad eutectic solder for the Ultimate in high fidelity signal transfer. All hand tested prior to shipment.
Another stage 3 kit that was made today ( Included sae Terminals and remote wire not in photo) this kit weighs about 60lbs in the 1/0, and about 70 lbs in the 2/0.
The Complete Stage 1 Wiring kit 2/0 AWG
Blue power red shrink, black power black shrink
I just edited in the terminals on this one, we have a large shipment of included SAE terminals coming in tonight and I wont have time to retake the pics as these kits will be packaged up ready to ship.
Building a Complete Advanced stage 2 wiring kit 2/0 AWG
here's some close ups, That PURE COPPER
cold weld! All connections are pre terminated with a 16 ton hydraulic crimper
GPcarAudio.com
Pro Seller
Supporting Vendor
GPcarAudio.com
Missouri
GPcarAudio.com
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
