The mystery of the internet displacement of sql12 driver
  • 3
Kybasshead75
CarAudio.com Exclusive
318
48
Ky
I have posted in multiple forms and blown up every line of communication with Nick at stereo integrity after spending $1,000 with him on three of these drivers and I still cannot find out anywhere what the displacement of the drivers are before I build the enclosure anybody have any idea?
Probably about .1 to .2 cubic feet. You could pick a similar size woofer from someone who does publish that spec and get closer but really if you planned for somewhere around there a difference of a few percent plus or minus on box volume should not be noticeable and if you have some very specialized needs you should be planning to measure, test, build, and re-build anyway so it's irrelevant
Yeah, about .13-.15 should be just about right, definitely close enough.
Just can't believe I've been completely ignored after spending $1,000.
Well, the odd thing is, page 3 of that manual shows the left socket as the rear view input, mute, and steering wheel control. While the right side...
OK, I kept on searching for the answer - found it! I was able to find an exact wiring diagram for my XVM279BT APPARENTLY the blue wire acts as...
3K
You probably did it already, but post this to 350z specific forums or facebook groups, etc. There's probably someone there that knows.
Kybasshead75
Kybasshead75
Ky
marc2112
