bbeljefe
Clean the battery terminals and trickle charge it overnight or, if you don't have a charger, drive it or leave it running for at least two hours. Then see if the battery can make it overnight. Also, make sure there's nothing turned on or plugged into the power outlet that may be causing a constant drain on the battery when the vehicle isn't running.
And if still acts up after cleaning battery terminals and charging it properly, take it to a local auto parts store (assuming they do this in SA) and ask them to test your battery. Here in the US they will do that free of charge so I can only assume that to be the case where you are.
