Thoughts on ported design
toybox
CarAudio.com Newbie
OHIO
I am looking at a design for a c-pillar wall in a small SUV. I started looking at the idea of a 4th order but ended with a ported I like where the 2x 15s point up from the box, then the port extends out of the box to wrap over the top of the subs. The bottom area is about 7 ft cu and the area above the subs is about 4 ft cu with the port being 3 inch slot all the way across box and ported about 32hz.
My main concern here is that this area the subs are firing into - will that cause issues with freq cancellation or try to act like a port that is not tuned? Trying to get okay SQ while focusing on decent SPL output (loud listening SPL not metered for comp SPL)
Thoughts?
Thoughts?
Can you provide some dimensions and maybe a better drawing of your idea? If the "slot" that the woofer is firing into is too narrow, you can indeed run into some issues.
overall the box would run about 40in wide x 30 in tall x 26 in deep with the port being the 40 wide and 3 tall at 32 ish length. I did already mod dimensions for 2 layers wood and sub displacement. it leaves this top area about 40 wide x 12 tall x 22 deep approx. I have all the exact specs mapped out but easier to speak in approx.
I have also come to learn about this creating "loading wall" that I can tune via a 1/4 wave calc but it seems at the moment that this would create a 140hz tune that would be rather useless - if I am understanding that proper.
What vehicle? Just make the box taller and put the port back inside the box at the bottom of the box IMO.
@Bobbytwonames it is going into a 2005 highlander. the reason I was trying the port up high was that i wanted to do a c-pillar wall and have that port shooting forward over the back seats.
that said, i think i am just going to try a series 6th order bandpass, internal tuned to 32 and external tuned at 55 with a 1:1 size ratio
Why so high? Why not 25 and 45?
Polk DB seem to always sound so much better than most for drop inns...
4
813
I treat my vehicles to an extent where they become some of the quietest examples of that vehicle. It isn't cheap if you're buying quality...
12
Looks like you could raise the back seat maybe 2 to 2-1/2" use longer seat bolts and washers and frame/mold in the under carriage cavity of that...
14
toybox
CarAudio.com Newbie
toybox
OHIO
winkychevelle
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
