C2 Audio 10+ year member
C2 Audio's THREATCON 2 subwoofers are our entry level woofers that will blow you away with how they perform. Below is the pricing information and specifications for both our 12" version and 15" version. Don't forget to like our Facebook page, subscribe to the YouTube channel, and keep an eye out for our upcoming pre-sales!!!
Pricing for the 12" version will be $129 with free shipping to CONUS.
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hz
Pricing for 15" version is $149 with free shipping to CONUS.
Specifications:
15" Threatcon-2 Subwoofer
600 Watts RMS
Dual 2 Ohm: Threatcon-2 15d2
Dual 4 Ohm: Threatcon-2 15d4
Dual Spider Pack
Sealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
SPL Version will be available, pricing and specifications will be announced at a later date.
Important Links!!!
C2 AUDIO || 12" Threatcon-2 Subwoofer
C2 AUDIO || 15" Threatcon-2 Subwoofer
C2 Audio | Facebook
C2CarAudio - YouTube
UPDATED T/S SPECS FOR 12" D4 AND D2
12" D4
FS: 37 HZ
VAS: 35 L
QES: .44
QMS: 4.02
QTS: .40
Le: 2.53 mH
BL: 25.1
MMS: 186.4 g
SENS: 88 DB
XMAX: 28 MM
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
12" D2
FS: 36.4 HZ
VAS: 37.1 L
QES: .46
QMS: 4.56
QTS: .42
Le: 1.84 mH
BL: 19.0
MMS: 182.2 g
SENS: 88 DB
XMAX: 28 MM
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
T/S SPECS FOR THREATCON 2 15" D4 AND D2
15" D4
FS: 38 HZ
VAS: 62.7 L
QES: .54
QMS: 3.72
QTS: .48
Le: 2.89 mH
BL: 26.7
MMS: 253.8 g
SENS: 90 DB
XMAX: 28 MM
EXT DIA: 15.5"
CUT OUT DIA: 14.125"
MOUNT DEPTH: 6.94"
15" D2
FS: 37.5 HZ
VAS: 59.1 L
QES: .50
QMS: 4.29
QTS: .45
Le: 2.16 mH
BL: 22.9
MMS: 276.6 g
SENS: 90 DB
XMAX: 28 MM
EXT DIA: 15.5"
MOUNT DEPTH: 6.94"
Specifications:
600 Watts RMS
Dual Spider Pack
Specifications:
600 Watts RMS
Dual Spider Pack
Important Links!!!
C2 Audio | Facebook
12" D4
FS: 37 HZ
VAS: 35 L
QES: .44
QMS: 4.02
QTS: .40
Le: 2.53 mH
BL: 25.1
MMS: 186.4 g
SENS: 88 DB
XMAX: 28 MM
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
12" D2
FS: 36.4 HZ
VAS: 37.1 L
QES: .46
QMS: 4.56
QTS: .42
Le: 1.84 mH
BL: 19.0
MMS: 182.2 g
SENS: 88 DB
XMAX: 28 MM
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
15" D4
FS: 38 HZ
VAS: 62.7 L
QES: .54
QMS: 3.72
QTS: .48
Le: 2.89 mH
BL: 26.7
MMS: 253.8 g
SENS: 90 DB
XMAX: 28 MM
EXT DIA: 15.5"
MOUNT DEPTH: 6.94"
15" D2
FS: 37.5 HZ
VAS: 59.1 L
QES: .50
QMS: 4.29
QTS: .45
Le: 2.16 mH
BL: 22.9
MMS: 276.6 g
SENS: 90 DB
XMAX: 28 MM
EXT DIA: 15.5"
MOUNT DEPTH: 6.94"
