Too little airspace?
if you stuff the box with 1lb of polyfill it will make the woofer think it is in a larger enclosure. you can get a couple lb bag of polyfill at a craft store for somewhere around 5 bucks.
You could use the polyfill, but I would recommend getting a bigger box down the road. One that will give you the recommended air space after taking the driver's displacement into account.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
john9721
john9721
Ankeny, IA
whitemax
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
