Trailblazer guys help
  • 6
Lbetts818
So I am working on a box for for Sundown e 12 v3s. Well I guess I'm more in the blueprint stage of the build. My question is do any new guys with the trailblazer have a good spot to put G 31 battery somewhere discrete? I have room for the box with the 4 12s but if I do that then I just do not have enough room for my battery back there. How do you guys with small cargo area's fit relatively big systems back there without wall in it?
---------- Post added at 07:44 AM ---------- Previous post was at 07:43 AM ----------
It's a 07 by the way
Id put tge barrety under the rear seat. You can get one small lithium under the seat..
He already owns a battery which is a g31 Duracell... he has a cab1600.1..... he does not need to buy a lithium battery that cost more then his subs and amp combined. God your stupid
Sell said battery for 100 buck. Buy a much smaller lithium that cost 120 bucks and is as powerful if not more powerful.
See i have 4500 watts in my car and i dont have issues.
Not to mention the next should ill be doing 150 from the trunk on a daily tune..
Before I did my 6th order wall,I had a 2 15 setup in the cargo area and I mounted 2 g31s in the little cubby spot then built a small false floor to raise the box up alittle
Is this what your trying to find room in?
It does not look like much room is available by building over the wheelwells... 4 12's huh?... seat up of course... IDK
I guess there might be after all... looks similar to my Blazer...
What is in that door in the floor?.. spare?
Between wheel wells is like what 42"? And build over them prly get like 48"
That's why it looks different... it's 42"... the Blazer is only 39" between the wheelwells... I knew something was off...
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Me too and then I have to paddle anywhere I want to go.
6
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
3K
Lbetts818
Lbetts818
Midland mi
Hertz Mafia
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
