Truck Cab Flexing?
  • 3
jackson
I also have a problem with the cab of my truck. I have my subs facing up and angled so they fire off the back glass.( I have 4-12's in a ext cab Extreme).Anyway the top of the cab is flexing and echoing to make the subs sound like they are distorting, listening from the outside of truck. From the inside though it pounds and is fairly clean bass.What can I do to fix this?Also what amp would be good to run with these pioneer IMPP 12's? Currently running a 500 watt Majestic that I've had for years.Hooked up 2 subs parallel per channel for 2 ohms per channel. I cannot read signs now with it cranked , but I want better.Appreciate all you guys help ,been out of car audio since high school now getting back into it. I LOVE POUNDING BASS .............//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
the easiest way would be some kind of damping material,ie: dynamat,second skin. pick a good heavy one, pop off your headliner, lay that stuff in, put ur headliner back in and ur in business. may not completely cure it, but will go a long way in doing so. may want to do the doors, back of cab, and floor if time and $ permits.
as to amp, RM likes the tsunami GPX1000, most like the jbl 1200.1, planet audio 1000d, little more cheese, mtx 81000d, rf 1000bd(or bigger) and the list goes on and on and on........................................................//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
something to try.. place your subs facing the floor aprox the height of the high area aginst the back cab approx 4 or 5 inches it will give you window rattling bass esp when windows are cracked half way i currently have this set up in my ext cab s-10 it pounds
I have dealt with several blow through sub setups over the years. Forget just trying to extend the port into the cab. All that you will hear in...
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
469
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
jackson
jackson
Huntsville,AL
jllbs12w3
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
