My Box
Slaymon
I need new audio eqiup
I already have a sealed box that is has to dual chambers with each being 3.2 cubic inches. I wanna convert it to a ported box. Would you recommend it or what? I would make the port and put an outter lip on it so it sticks out 3/4 inch. Ok, what I'm trying to figure out would it matter how far the port sticks out of the box as long as the port volume is the same? Because I'm gonna put an outter lip on the port slide it in and then drill then lip to the box. Would that be ok?
Yep it will work. as long as the port dimensions are the same. The port can protrude from the enclosure. As for wether you should port the enclosre or not. That depends on what kind of subs. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by ramos Yep it will work. as long as the port dimensions are the same. The port can protrude from the enclosure. As for wether you should port the enclosre or not. That depends on what kind of subs. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So your saying that if I put my port in the box with a flush front, that would be the same as if I mounted the port on the outside with the back of it being flush with the inside of the box? I always thought it depended on how much of the port was on the inside of the box so it would capture a certain freq. as it came off the back wall. The distance from the back wall and the end of the port would determine the wave it would capture.
Nope. you can extend the port outside the enclosure if needed. Just remember to not add the port displacement in when your building your enclosure. Or your tuning is going to be off slightly. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As long as the port volume is still the same, its all good?
By the way I have 2 12" HE2's and Soundstream Picasso 880.2 pushing them. Just curious, you dont happen to know if the new Soundstream line is still underrated do ya?
Originally posted by Slaymon As long as the port volume is still the same, its all good?
Yep
And yep //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So i could make a 50 foot port and route it to come inside of my window and lose no sound quality? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by bobhope So i could make a 50 foot port and route it to come inside of my window and lose no sound quality? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It would probably sound like a$$ due to the funky tuning with a 50 foot port //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif But it could be done if that length of port was required. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hehe, probably sound pretty bad, but its something to try...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
- Steve
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
410
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
760
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
599
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
Go get some shitty wood or cardboard or something and figure out what the max is, play around with different dimensions to see what the max cubic...
23
Slaymon
Slaymon
Indianapolis, IN
ss3079
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
