Southeast Region Truck scores and setup?
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
  • 4
4 door or 2 ?
Thats ****** for 1 12. Did it play music?
I going to seal off the trunk. I can dump alot more power but i get .7ohm rise ove facing back.. so to gain i need more power after rise.
Going to use a 8 layer very short coil to get a **** ton of b/l and it should take 3k clamped for burps.
Thats ****** for 1 12. Did it play music?I going to seal off the trunk. I can dump alot more power but i get .7ohm rise ove facing back.. so to gain i need more power after rise.
Same setup did a 153 in my Focus ZX3 hatch on non running voltage just a battery in the trunk
I've been thinking of doing another trunk car ..in my dodge dart I did a 149.8 with two HDD 10s on my DD M4 in a trunk setup just wired to a battery ( Kinetic 2400) at a show ..later discovering I had a bad sub //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif ..I pulled everything out of the car the next day ..
****. If you gonna do trunk we gonna compete!
I was contemplating doing a wall with 218 but since you good at trunk I'll stay in trunk.. hehe
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
314
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
3K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
Papermaker85
Banned
Papermaker85
New orleans LA
Louisiana_CRX
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
