Southeast Region Truck scores and setup?
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
  • 4
I plan on playing with one 10 ..and maybe my DD M4
so you going to make me feel guilty? lol
im going to add a resistor tw my line sensor and see what happens.. if i cna get 15 volts my amp will do 4k and will be much more efficient..
What vehicle is your trunk setup in ?
kia optima..
---------- Post added at 09:12 PM ---------- Previous post was at 09:11 PM ----------
no doubt i break 150 outlaw. Im gonna try for hte record in 2k clamped. gonna build a driver just for the install. lol
If I can't get the Mercedes right I may redo my Dodge Dart
well stock used to be about in hte trunk buy everyone is sealing off. that bing said alot of people have larger cars despite being harder to seal off they can shove 2 15s even 2 18s in a 6th order and get it to peak hard. we will be at a serious cone are disadvantage but that's not always the case. I thught about do sup bu port out hte side on the rear corner of the box but my trucks super small..
You can see in my Saleen video a shot of my trunk ..that's a true trunk box nothing protruding into the cabin the seat was folded down
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
284
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
3K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
Papermaker85
Banned
Papermaker85
New orleans LA
Louisiana_CRX
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
