Southwest Region Trunk car class.....????
AZ,CA,NM,NV,UT
hmm do you know the avg DB range of superstreet NW? what is this hahaha ****it I tried reading the rule book but its crazyyyyyy....either that or im just idiot
Assuming youre wanting to run in db drag, SS no wall...due to the extra batteries. But if you wanted to drop down to street you could by disconnecting the rear batteries for the run. And scores are pretty much all over the place in nw but you'd want to be in the high 40's+ to be competitive
with only one extra batt u coulld do street c. without any xtra batts its street b.
x2, I would take one batt out of the trunk and do some runs in street c...I completely forgot about it //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
795
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Bhhong
Bhhong
SD DAYGO CALI
Scuba
maylar
    Jun 2, 2024
    Jun 1, 2024
