Trunk issues
Plus I notice the zv4s do not like high notes along with x series
they are just so efficient down low people put them in larger alignments because they want peaky lowend. the z4 12s in 1.75 tuned to 35 would easily hit hard uptop. it hurts power handling though but it handles PLENTY of power handling i assure you.. Id say 1.9 tuned to 36 would be good for most people who like the punchier stuff. they still do fine on the lowend tuned higher
Usually the people saying the megaroll sundown doesnt play high, are people putting them in huge enclosures tuned low. Jacob said as much. I see alot of 12s around 3cu, tuned at or below 30. They definately wont play to 60 like that. A buddy put an X 10 in 1.4 @35 or so. It played a pretty normal bandwidth
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
825
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
CALIBASS2014
ZANESVILL OHIO
CALIBASS2014
Decebal
    Jun 10, 2024
