Vent noise problems
  • 2
XxAndreaxX
spain
Hello, I have the following problem:
the sub is too big and powerful for the enclosure.
I can't change the enclosure, I can't change the sub. I can't make the vent hole bigger.
Now I've tried both sealed and ported. Ported sounds still good but much stronger.
My problem is, the vent hole is too small, so at higher pressure, I hear some noise of the air.
My solution was to put another vent into the box, but the calculator tells me, both vent lenght are much longer now. so if I put another hole in it, should both tubes be longer, in order to keep same tuning freq??
thanks
Hello, I have the following problem:the sub is too big and powerful for the enclosure.
thanks
Yes. For more port area the port must be longer to get the same tuning.
Maybe I'll run up to battery shop on vacation in a couple weeks and see what they can do...they do a lot of fabrication for trucks and farm...
17
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
XxAndreaxX
spain
hispls
