Trunk issues
VikingBrian
Ok. So I know the forum is called interior/exterior enhancements and I figured this barely fit. I need help guys. I have a 1999 toyota avalon. My trunk keeps rattling. I bought some weather stripping to help. So far I've applied it to the inside of the fuel lid, the edge of the trunk and I've even taken OFF the license plate to put W.S there. Sadly it still sounds bad. Please advise!!! To the mods out there, sorry if this is in the wrong spot.
Sound deadener is probably your only out here. I know it seems expensive, but it's not as bad as you think. I use Noico 80mil and it works very well. You can get 10 square feet on Amazon for $20. That's enough to do your trunk lid and sides as well as take care of the license plate. You can also pick up a roller for $10 to install it with.
https://www.amazon.com/Noico-deadening-automotive-Insulation-dampening/dp/B01KZ5X7KO/ref=pd_sim_263_6?_encoding=UTF8&pd_rd_i=B01KZ5X7KO&pd_rd_r=DNRZ11W4K1EVNTYQ97AN&pd_rd_w=Z0jGq&pd_rd_wg=J5yy1&psc=1&refRID=DNRZ11W4K1EVNTYQ97AN
you'll need some deadener and a giant can of great stuff expanding foam, fill in all cavities of the trunk lid. Also get some screws to fully screw in the top and bottom of the license plate.
I just looked at the sound deadner. Are you sure that's what I need? I'm not 100% sure where the rattle is even coming from. I barely hear it in the car and outside is horrible. I pushed on the bottom of the trunk, right below the license and it stopped making the noise, but I had to push kinda hard. Same recommendations?
You could also look into GP STFU deadening its really thick.
You know how badly this would make a great reply?!
Oh btw, I have some of that GP deadening....stuff is fairly thick, kinda like memory foam on one side and the other side a thin layer of adhesive matting.
Turn the box around and face forward.
I actually ended up doing this since my license plate was rattling and so was the interior emergency trunk release.
I’ve read it doesn’t sound as great when facing rear seats versus firing towards rear of car, is this true?
I actually ended up doing this since my license plate was rattling and so was the interior emergency trunk release. I’ve read it doesn’t sound as great when facing rear seats versus firing towards rear of car, is this true?
Well, does it sound better?, Generally facing the trunk is louder unless, you seal it if while facing the cabin..
Sent from my SamsungLife using Tapatalk
Honestly I’ve noticed such a small difference that’s it’s me negligible compared to before with all the rattling.
I’m waiting on sound deadening material to hopefully help out.
I know I know...I just wanna eliminate as much as possible. Back in the day I used pennies with my 1990 Buick!
Let us know if you manage to mitigate the rattling your referring to! Especially your plate rattle
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
677
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
VikingBrian
VikingBrian
Cynthiana, KY
SoCalArgento
slater
    May 2, 2024
slater
    May 2, 2024
