Trying to figure out how to hook up new h/u to my factory bose. Got all the specs
  • 3
scheibler
Alright I drive a 1991 Acura Legend LS with a broken h/u. It is equipped with a bose headunit, 80x4W Peak Power Bose Amp(made by kicker) behind the rear seat, 6.75 front speakers, and 6x9 rear speakers. The speakers function at a 2 ohm load per channel.
This is the H/U I plan on buying...not sure how many ohms per channel it puts out though http://www.sonicelectronix.com/item_22096_Eclipse+CD1200G+w-+IPC-009+iPod+Cable.html
Not sure what would sound better? Running my factory speakers off of the aftermarket h/u or using a LLC (Line Level Converter) in between the h/u and bose amp. What would I connect my stock amp to the h/u with?
Thanks in advance! Any help is greatly appreciated. Driving around with no music is killing me //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
If you can find a harness adaptor for the car then you can run thru the factory amp. Otherwise I would get rid of all the factor stuff and replace with new amps and speakers. If your budget is tight, Start looking for the harness.
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
571
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
scheibler
scheibler
St. Louis, MO
loudassbug
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
