Wiring help
wtf is google??? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
anyway you can not wire 1 4ohm sub to 4 ohms you would need two of those but you can however wire 1 2 ohm sub to four ohms by wiring the voices coils in series then the sub and amplifier in parallel so if you want 4 ohms buy the 2 ohm woofer
Useless posts are useless posts if he doesn't get it after I told him and gave him a link for everything he needs then don't bother... He obviously ant read and doesn't wanna do work himself.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
633
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
995
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
SpedBoy
SpedBoy
Brighton, Mi
Wildbillpb
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
