Tundra speaker recommendation
  • 2
Jimg
CarAudio.com Regular
216
13
New project
2016 Toyota Tundra crew max
I will be replacing the head unit
will be using a dsp with 8 channel output
I want to run a three way active setup up front , rear door speakers will not used
sub amp Probably 500-600 watts true watts
what shallow mount 10 inch subwoofer would be a good option. Will have no more than around 5 inches in mounting depth to work with. Probably will have around 1.5 cf of space to work with.
best option for around $300
best option for around $150
will be using a 4x100 watt amp.
on channels 1 and 2. What 6 1/2 would You use
what $200 option would you use
what $100 option would you use
channels 3 and 4.
replacing the dash speakers
what 2 1/2 speaker would you use
$200 range
Tweeters
on a separate 2 channel Amp
probable a 75x2 watts
what option would you go with
$200 range
$100 range
if there is a better option than above I am open to other Options
if the 3 way setup will not be a big jump over just the tweeter and 6 1/2 setup I am not dead set on the 3 way
a basic 2 way up front would allow me to just use the headunit and not be out the cost of the dsp
If you enjoy fiddling with you system a lot and fine tuning for hours and weeks, go with the 3 way. If you want more of an ease of use, just do a 2 way. Running 3 way active up front is a lot of work, which is the point for some people.
Hey there - New on here as well and also a new Tundra owner. I have a 2021 SR5 and sadly they have not updated the stereo since before your model...
24
3K
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
949
Update I have been playing with the silver flutes and just can not get what I want out of them. I spoke to stereo integrity today and ordered a...
9
The L7S are 1500 combined and I’ve got 1200 currently, so I need a larger amp. I have voltage drop with the 1200 when I’m pushing them
6
872
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
199
Jimg
Jimg
SlugButter
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
