Tundra speaker recommendation
  • 2
Jimg
CarAudio.com Regular
217
13
New project
2016 Toyota Tundra crew max
I will be replacing the head unit
will be using a dsp with 8 channel output
I want to run a three way active setup up front , rear door speakers will not used
sub amp Probably 500-600 watts true watts
what shallow mount 10 inch subwoofer would be a good option. Will have no more than around 5 inches in mounting depth to work with. Probably will have around 1.5 cf of space to work with.
best option for around $300
best option for around $150
will be using a 4x100 watt amp.
on channels 1 and 2. What 6 1/2 would You use
what $200 option would you use
what $100 option would you use
channels 3 and 4.
replacing the dash speakers
what 2 1/2 speaker would you use
$200 range
Tweeters
on a separate 2 channel Amp
probable a 75x2 watts
what option would you go with
$200 range
$100 range
if there is a better option than above I am open to other Options
if the 3 way setup will not be a big jump over just the tweeter and 6 1/2 setup I am not dead set on the 3 way
a basic 2 way up front would allow me to just use the headunit and not be out the cost of the dsp
If you enjoy fiddling with you system a lot and fine tuning for hours and weeks, go with the 3 way. If you want more of an ease of use, just do a 2 way. Running 3 way active up front is a lot of work, which is the point for some people.
Hey there - New on here as well and also a new Tundra owner. I have a 2021 SR5 and sadly they have not updated the stereo since before your model...
24
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
968
Update I have been playing with the silver flutes and just can not get what I want out of them. I spoke to stereo integrity today and ordered a...
The L7S are 1500 combined and I’ve got 1200 currently, so I need a larger amp. I have voltage drop with the 1200 when I’m pushing them
901
99
Jimg
Jimg
SlugButter
audiobaun
    May 19, 2024
    May 19, 2024
