Undo soldered wires
Guyver
If speaker wires to the radio is soldered and wanting to put in a new stereo, can I cut in between the soldered joints or make a new cut? Soldered makes it look neat and clean but isn't harder to work around it compare to wire crimps?
I personally have always liked heat shrink and soldering if you have the tools and patience for it.
It's NOT rocket surgery!
Just remember, PUT THE HEAT SHRINK TUBING ON THE WIRE before soldering it! ;-) Been there, made THAT mistake!
John Kuthe..
Just cut off the pieces of wire with solder on them and then make your new connections. If you do crimp use crimp caps or butt connectors and make sure to do a proper crimp. Solder is the best possible connection but crimp connections are acceptable on a radio harness. The biggest issue with crimped connections is improperly crimped connections.
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
9
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
7
Try placing the subs in the front seat, to see if the issue persists. Just for diagnostic purposes. It may be wiring, but the distortion may be...
963
Guyver
Guyver
St. Paul, MN
Zero_Ohms
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
