Universal Headlights Help!!
  • 1
DJDroc22
Hey guys has anyone tried the Modify Street Universal Headlight sensor?
Universal Auto On/Off Headlights Sensor w/ Switch :: Auto Headlights Sensor :: Auto Accessories :: ModifyStreet
I'm trying to install this into my 01 Explorer Sport (2 door)
And I did the +12v constant.
Ground..
ACC +12v..
An then I connected the headlight signal wire but when I start my car my horn goes off and I can't stop it unless I hit the On/Off button on the sensor. So I figured I wired into the horn trigger wire so I completely disconnect that wire to see if the horn has stopped when I start my car.. but it hasnt... and now the module is only connected to Power and Ground and it's still activating the horn? I'm officially confused..
If anyone has installed this Module before then please Chime in and help me out! Anything helps. Much Appreciated!
BTW //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'm New to the forum and will my updating my profile and posting new soon!
  • Locked
Hooked up to verify that it works, but decided to go hard-wire instead. I've verify that this support SBC, AAC, AptX and LDAC. Condition is like...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
187
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
553
DJDroc22
DJDroc22
United States
DJDroc22
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
