wiring two switches for one led?
  • 3
sb220
VA
Im working on installing LED strip lighting in my truck camper shell and would like to have a switch in the cab and rear of the truck to switch on the same lights.
I can wrap my head around wiring them up in series, creating a "master switch" closest inline to the battery.
However, Im wondering if its ok to wire them up in some kind of parallel....
+--switch
..............\___ Light
+--switch
Is that the way to do it or would it require diodes to prevent backfeed....can a power source actually backfeed on itself?
Thanks
Your switches need to be SPDT. You wire them like this...
Now either switch will toggle the state of the LED strip
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
101
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
362
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
668
sb220
sb220
VA
sb220
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
