DarkKnightSM
Go figure! I finally got my mechman alternator install done, belts tight but not to tight. No squeeks, everything tight and secure and terminal to metal surface areas sanded down awhile ago.
Yet i still have headlight dimming. Infact a new symtom has been added, now, at idle, when the bass hits, the car **** near stalls!? However, this is only on the first bass note hit. Subsequent hits do not effect the rpms hardly at all. Id have to pause the music and start it again for it to almost stall again. The whole time i was reading about 14.37 to 14.28 on MY volt meter. So then i took it to advanced auto parts for them to test with their fancy tester and theirs says pretty much the same thing
Except!, a drop down below 10 volts early on, but that portion appears to be from starting? Idk it appears the info on the printout is conflicting.
Anywho im almost positive that a stronger battery is nesesary to compentsate for those first bass hits, theres also something in my car called an ELD or something, i forgot now. Regulates the load pulled from the accessories. Maybe i should look at that too
Note: not pushing more then 600-700 watts max and stock alt was 70 amps, mechman alt is 240.
Oh and my thinking for a new battery works like this...the first hit comes from the battery because my alternator was "surprized" by the sudden demand for electricity. My interstate battery couldnt keep up, hence the close to stalling, but luckily after a few split seconds the alternator supplies the battery with what my system is demanding. But my question is why wasnt i having this problem with the stock alt. Sorry for being wordy, just trying to get all the info out there
