Upgrade for my system
  • 3
So I've built my system a few months ago.
I'm running 2 Pioneer Champion TS-W309S4 12" 2800 Watt Peak / 800 Watt RMS 4 Ohm subs. I'm powering that with a Sony Xplod 1000 watt 2 channel amp.
My doors are 4 Kicker - CS68 6" x 8" @ 225watt peak/ 75 RMS. I'm powering 4 of those with a Polk PA660- 4 channel 600 watt amp.
I am powering these amps with 2 1400watt max cable, running from the battery.
My question is: I want to upgrade. What subs will be a significant upgrade and what amp could I get to power those subs?
I was looking for something more powerful than my current system. Still sticking with 2 12's. My car is a 2007 Ford Focus. Budget: up to $400 or $500.
I am aware that i am not giving my 2 subs now what they need power wise, but if someone could recommend a good amp that'll be enough to handle those 2 subs, I would be thankful.
Change your power cable to OFC for starters if its not if your planning on running more than 1000watts... A single 12 in a proper enclosure would probably amaze you if powered correctly.
---------- Post added at 10:11 PM ---------- Previous post was at 10:10 PM ----------
You dont need an amp to handle subs, you need subs to handle an amp
It doesn't really matter. I just need to be pointed in the right direction. I can old off on the 12's now that I think about it. I am still thinking of a 4,000 watt amp though.
i have no experience with component speakers. Maybe someone else can help in this area.
DIY system turned out not that good....... 2014 Honda pilot (No metra Kit) so I have to keep factory HU I cut wires behind head unit and ran...
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
459
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
571
bs199sg
bs199sg
United States
bs199sg
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
