Upgrading Only Tweeters
Yeah if u just have stock the u want to replace and and get component speakers. I'd recommend getting and amp for them also. What gauge wire is ur amp power wire
0ga welding. I'll need help with the component set up cause I'll be lost. I can install the hu & subs & sub amp with my eyes closed but the speakers or a 2 amp setup I've never tried
I've had my eyes on the ID CXS62V.2. Any opinions?
This amp for starters. Thats a very cheap route. But will be an improvement over stock. As for speakers. You need to tell me what size you have in your doors. You have a stock location for tweets?
Precision Power PPI S320.4 Sedona Series 320W 4-Channel Amplifier
I don't have to go super cheap. Also I'm not really into sq. I'm a spl person. I'll probably go with an American Bass amp to match my sub amp. & 6.5" speakers up front. Separate place for the tweeters in the doors
I know but if I can't hear the words then I'm backing it down & yea
You said you turned up the gain not turned it down.
What HU do you have? May be limited on number of preamp outputs if you want to run a 4 channel amp.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
502
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
678
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
9
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
When I stripped my factory system and started from scratch. I didn't need any adapters. I wired the new head unit wiring harness to the vehicle...
8
996
Fordking
Fordking
Atlanta
Fordking
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
