Upgrading Stock Speakers
  • 2
Nick2
CarAudio.com Newbie
Hey all,I have a 2015 Fiat 500 and I'm working on replacing the stock stereo system. I was initially working with the Infinity Reference 6532ex speakers for the front, and after replacing the stock set with those, I only noticed a 10-20% increase in performance from the stock speakers. The Infinity's were also very bright, and had basically now low end. While that may be the characteristics of the speaker, I could not imagine such a small increase in performance from switching out the stock set that came with the car. Could the stock head unit be the culprit in limiting the true sound quality coming from the speakers? I also tested Morel Maximo 5s and there was also not much of an increase in the performance, they were awfully quiet, which is understandable for a 5 1/4 speaker.
What I want is a speaker set that produces accurate sound, does not have boosts in the highs or lows, and is undeniably clear.
Yes could be the stock headunit but also it is power and sound deadening. Aftermarket speakers require more power to come alive. You should do some research into sounddeadening and get some CLD and Soundskins rings.
Harsh tweeters are common on lowend speakers. The Morel Maximo 5 would be a better set than the Infinity's as for the tweeter harshness. They are quieter because they are 4 ohm compared to the 3 ohm of the infinity's and also sensitivity is higher on the Infinity's..
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
590
HI all, I am thinking of upgrading from the stock sony radio in my ford focus 2008 to the Sony DSX-B700. Would this be a worth while upgrade for...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
240
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
9
Nick2
CarAudio.com Newbie
Nick2
ckeeler11
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
