USB-C to 3.5 Dongle VS 3.5mm to 3.5mm
  • 3
GenY
CarAudio.com Recruit
53
4
USA
I was wondering if anyone knew if a USB-C to 3.5 dongle would give better audio vs a 3.5mm to 3.5mm jack? I was thinking about getting this - HIDIZS Sonata II - https://www.amazon.com/dp/B07F2DTTGT/?tag=caraudiocom-20
I have a Samsung Galaxy S10 and it does have a 3.5 jack but it doesn't sound quit as good or hit as hard ( subwoofer) as my USB flash drive that has FLAC songs on it. I'm trying to stream Amazon HD songs on my aftermarket JVC head unit.
Thanks for any advice.
This seems like something I would try if I was trying to achieve what you want. The straight 3.5 to 3.5 will not improve your sound quality, only send the original signal to the head unit??? The USB Dongle claims to improve sound quality. Give it a try. If it works, the problem solved. If not, Amazon has a great return policy. Make sure you keep all the packaging.
All you are doing is boosting preout voltage(if you have an amplifier). If you have a relatively new head unit, Use bluetooth and reset your gains. Aux is like the worse. Theres different audio levels between sources which is why head units like pioneer has a source level adjuster to make output uniform through all sources. This is all mainly settings issue that you can fix for free without buying headphone amps that could potentially blow your speakers and subs because you can easily clip from boosting the signal too.
Alright thanks for the advice. I was also wondering if after setting any EQ or Sound Effects within the head unit I could test for distortion uning the SMD - DD1? Could I play a test tone from the phone or a cd to test for any distortion? Thanks again.
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
e heard decent things, I've not used it, but for noobs, good place to start with that new DSP setup...
For anyone that has an Alpine ilx-w650, do you have a crappy shuffle feature when using a USB or is it just me? A little background, I have...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
GenY
GenY
USA
GenY
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
