Used ARC Audio KAR400.4 - 4 Ch Amplifier
  • 2
NIHL8ION
RUN ur car NOT ur mouth !
1,373
IlliNOISE
Item(s) for Sale: Used ARC Audio KAR400.4 - 4 Ch Amplifier
Item(s) Description/Condition: Used and it shows: Scratches and typical use over the years - Functions 100% FLAWLESSLY - Very Efficient little amp with good sound and power for it's size.
Specs:
Measured output power (At 14.4 Vdc less than 1% THD+Noise): 70.2 x 4 into 4 ohms, 124.2 x 4 into 2 ohms, 248.5 x 2 into 4 ohms bridged.
Measured Current Draw (At Max Power): 27.8 amps into 4 ohms stereo, 47.7 amps into 2-ohms stereo and 4 ohms bridged
Measure Amplifier Efficiency (At Max Power): 70% amps into 4 ohms stereo, 72% amps into 2 ohms stereo and 4 ohms bridged
Measure 1/3 Amplifier Efficiency: 32%
Signal-to-noise dBA (Reference 1 watt): 92 dBA
Rated OutOutput power: 50 watts x 4 @ 4 ohms, 90 watts x 4 @ 2 ohms, and 180 watts x 2 4 ohms bridged
Transient distortion: less than 0.1% @ 4 ohms
Frequency response: 20 Hz-20 KHz
S/N ratio(A wtg): greater than 95 dB
Bass boost: + 18 dB @45 Hz
Input sensitivity: 250 mV - 2.5 V
Crossover: 55 Hz-5.5 KHz variable 12 dB
Fuse: 40A x1
Dimensions: 13 inches x 8.5 inches x 2.5 inches
Arc Audio KAR 400.4
Price: $100 Shipped CONUS
Shipping and Miscellaneous Item Information: Included - (CONUS Only)
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). NIHL8ION
I own one of the S.M.S.L SU-1 MQA MQA-CD DAC. I got it to play off my stable platter CD player, a Pioneer Elite PD-59 that I use as a transport to...
10
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
14K
NIHL8ION
NIHL8ION
IlliNOISE
NIHL8ION
