HollowHills
CarAudio.com Newbie
5
I have a Memphis Audio PRX1000.1 powering two Sundown EV3 10'S. Subs are wired to a 1 ohm load. So the issue I keep have reaccuring is the amp will suddenly quit providing output to the subs, when this happens I can reach back and literally just touch the amp with my hand or even just a finger tip and output comes back and subs start playing.  The blue status light never changes to red or cuts off or anything just stays blue as if everything is fine. Amp isn't hot to the touch, no popping or chirping or anything issues with the sound when it is playing.  There is no pattern as to when the issue occurs. I could be sitting still in my drive way this it just cuts off, driving down the road, music up loud, or music playing on low. Then just reach back and touch it and they kick back on. I've also noticed this issue while adjusting knobs on the amp, like I'll tweek the LPF and it'll stop, touch the knob again with the tip of the screwdriver or something and it'll kick back on. It's extremely annoying and this is my second amp being that I exchanged the one right before it (same make and model amp) because it had issues. I know it's got good ground I recently just added a new dedicated grounding post just for it.
So my question is, has anyone had similar issues I'm having before with this or any other type of amp?  If so did they ever figure out and/or solve the issue?
This is an extremely vague requirement. Potentially killing their brand name among developers and potentially initiating a slow long decline into irrelevancy certainly counts as not acting in their shareholders' best interests. When google first started, their "don't be evil"Tutuapp 9apps Showbox mantra was one of the main reasons they succeeded, so not doing unethical **** is in their shareholders' best interests.
Get out...
Is your amp mounted on your sub box? I've read that vibrations can rattle components loose in your amp, though have not had it happen personally. I'm having a similar issue with my MTX 6500D, only mine comes on and off on its own, regardless of how hard I hit it. I would try (am trying) to figure out exactly what is going on when it quits. Check all your connections; make sure all connections are metal-to-metal. Check voltage on your RCA's and remote wire when you lose audio to rule out your deck, and make sure your RCA's fit tightly on both the deck terminals and amp terminals. Check for voltage on your amp's output terminals when you lose audio.
As ThatPurpleKush suggested: check your ground. Do you get shocked when you reach back and touch it?
Hope this helps.
- Joe
i place my flag in the "check your ground" camp. On both ends too. How did you connect your ground to the chassis? If its a self tapping sheetmetal screw, youre gonna wanna redo that ****
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
857
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
HollowHills
CarAudio.com Newbie
HollowHills
Zer0C00l
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
