viper remote kills batteries??
  • 3
maybe your accidentally holding a button down alot of the time? your using cheap batteries? you have a lemon remote? the remote just overall *****?
I had a remote that was doing that so I opened it up to look at the traces and contacts. There was some type of residue from a previous cleaning or whatever. I took alcohol and a cotton swab to everything and followed it up with a dry swab. That fixed my problem.
Had this type of traces.
피크를 사용하지 않을 계획입니다.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
341
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
Audio4ever
Box Chevy Boi
Audio4ever
Maryland
ciaonzo
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
