voicecoil wiring options
here comes the boom!! duck and hide!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
EDIT - new avatar text.
thanx for the idea.
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
hey im going to hook up a 12" kicker L7 tomorrow and its a dual voice coil...the previous subs i had were single so im not use to the dvc....is possible to run 2 channels independantly to the 2 voice coils or what...how could i set this up...i got a ppi a600.2 gonna be powerin it
Is there any way to wire (2) 4 ohm DVC subs to an amp for a 2 ohm load on the amp? I don't see it in the diagrams. All I see is a way to do it at 1 ohm or 8 ohm loads on the amp?
i got 2 D2's and a tsunami bd1800t amp. the amp is i think 1x1800w at 2ohms. soo what series would i want to use. for the d2 subs. i want 900watts to each one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif and that amp is mono
You just cut two pieces the same length, and connect the negative together at each end, and the positive wire the same way, basically connecting...
38
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
116
365
359
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
    May 18, 2024
    May 16, 2024
