walled or trunk ported
Trunk ported, highest sol #'s do not come from walled set ups I'm pretty sure, somebody correct me if I'm wrong. For example, my eclipse would sound better with a trunk style ported design because if I walled the vehicle, I would lose the hatchback effect. Walls are also generally more expensive. Hope this helps.
loudest trunk at worlds were sub /port forward with box pulled all the way back against rear of car...but every car is different...what is ur goal? what setup do you have in mind ? is this going to be a daily setup or for competition only ? what kind of vehicle is this going in ?
I assume you are asking about a sealed off trunk or a my standard setup...not actually asking about "walled" correct.
When did it become common for sealing off the trunk to be called "walled", they are not even close to the same //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Yeah, I've seen it at least 3x recently and each time I get confused for a split second, then rage for another second lol. I think all the kids who want to seem hardcore like the idea of saying they "walled their vehicle" without actually doing it right and pulling the back seats.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
748
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
mensah0077
mensah0077
lincoln park
Buck
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
