Design is half way there..
  • 2
solidcrowd
Okay so I've attached a picture* of drawn to scale design I made up with the dimensions I'm shooting for.
I need help finishing the design and a cut sheet would be awesome!
I have TWO Dayton Audio RSS315HO 12" subwoofers that I want to put in the perfect Aeroported enclosure. I have 26-27 inches in width and 16 inches in height. Will be using of-course 3/4" MDF wood and TWO 3" PSP flared aeroports. Also, they will be powered by an Alpine PDX1.1000
POWER: 1,114 wrms
TUNING: 30-33Hz
MUSIC: Rap and Rock (Chevelle)
PARAMETERS:
Resonant Frequency (Fs) 20.9 Hz
DC Resistance (Re) 1.7 ohms
Voice Coil Inductance (Le) 0.83 mH
Mechanical Q (Qms) 4.26
Electromagnetic Q (Qes) 0.42
Total Q (Qts) 0.38
Compliance Equivalent Volume (Vas) 2.12 ft.³
Mechanical Compliance of Suspension (Cms) 0.16 mm/N
BL Product (BL) 13.7 Tm
Diaphragm Mass Inc. Airload (Mms) 351.5g
Maximum Linear Excursion (Xmax) 14 mm
Surface Area of Cone (Sd) 514.7 cm²
Power Handling (RMS) * * 700 Watts*
Power Handling (max) * * 1,400 Watts*
Impedance * * 2 ohms*
Frequency Response * * 25 to 500 Hz*
Sensitivity * * 83.2 dB 1W/1m*
Voice Coil Diameter * * 2.5"*
Magnet Weight * * 150 oz.*
I can design you a box for a fee if you'd like. I just did a pair of those a few days ago.
If you don't mind me asking, what cuft did you put them in and what were they tuned to? Also, how do they sound or what do they compare to? It's between these or getting my 12" AB XFL replaced..OR my 12" Si Mag Claw reconed by a local guy.
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
530
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
838
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
742
solidcrowd
solidcrowd
Buffalo, New York
solidcrowd
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
