Was anybody waiting on those new Dayton UM Subs?
  • 6
WinISD predicts qtc of 0.95 in a 1.5 cu ft box. Usable, but it looks like 1.5 cu ft box is a bit small for it. As for the 10 inch Ultimax, you get 0.7 qtc in a 1 cu ft box or 0.8 in a 0.6cu ft box. Much better.
Personally, I am still waiting for opportunity to try out Dayton HF subwoofers. Their power handling and xmax excursion seem low, but these are supposed to be pure SQ drivers, with low inductance, with great performance on Klippel. Unfortunately, these don't seem very popular in car audio. The HF12 is clearly designed for bigger sealed box, more suited for home audio, but the HF10 seems usable (about 0.8-1cu ft sealed box for a good box qtc)
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
3K
skylineTT
bass=sekz
skylineTT
Houston/Dallas
jockhater2
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
