Weird electrical issues after amp install...
  • 4
gaddydaddy
I have an 08 silverado. I installed an amp to my door speakers and after started having some weird electrical issues. My silverado had the bose system which I bypassed to install a rockford fosgate 4 channel amp to JL door speakers. One problem I'm having is when I use my left blinker it blinks normal 3 times, then after that it doubles its speed and blinks twice as fast. I didn't have this issue until I hooked up my amp. The second issue is that when I put my truck in reverse there is a pop and then staticky/whiney noise that comes from my speakers. I also don't have a radio in at the time because I took it out to replace the pico fuse. Any ideas on how I could fix these problems? Thanks
I got the radio installed somewhere and they were supposed to install the wiring harness, but I just spliced my wires from my amp into the speaker wires underneath the center console.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
gaddydaddy
gaddydaddy
Mississippi
jco1385
    May 18, 2024
    May 18, 2024
