Weird issues with Remote Input on the amp/Protect Mode
  • 1
ChaoSki
6
CT
Few weeks ago my amp started to produce crackling on start up. It's powering my interior speakers and right side would make weird noises. At first it would only do it on start up, but it progressed to louder sounds and eventually the amp would go into Protect mode.
Yesterday I unplugged the speakers from the amp and turned it on to see what would happen. Sure enough, amp goes right into protection mode. Figured it can't be the speakers/short. I removed the door covers and double checked the wiring regardless, all seems fine.
So I started checking Voltage on Power and Remote. Seems fine. Also jumped Positive to Remote but the amp still goes into protect mode (no speakers hooked up).
I run the remote wire daisy chained to 2nd amp as well (Sub) and that one is fine.
So I plugged the speakers back up and plugged the remote back in while car was on, noticed the amp/sounds would go on, same crackling and as I moved the Remote/tightened the screw it would distort/cut off speakers and go into Protect mode.
Almost seems like there is some kind of a short on the inside of the amp/remote connection?
My next step was going to be to take the amp apart and see if I can spot anything.
Also, this morning it crackled at first, played music for about 2 min....cut off into Protect Mode. It's been random.
Amp in question is: MBQuart Onx2.100
TIA
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
ChaoSki
ChaoSki
CT
ChaoSki
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
