What 1/0 Solder Terminals do you recommend
Looking to get some Terminals for the Big 3 upgrade, but not sure what the best ones to get are.
I saw these: Amazon.com: Pico 4439C 1/0 AWG Battery Cable 3/8" Tubular Lug Ring / Eye Terminals 15 Per Package: Automotive
and thought they look pretty good but wanted to see what others recommend
I'm going to solder them, don't want crimp ones for this.
Thanks!
Those look good, I been using these for a long time. Tinned Copper Cable Lugs Ring Terminals AWG Welding Battery Marine Cable Wire | eBay
Are you experienced with soldering heavy cable ? If not grab a hydraulic crimper even the harbor freight one work great. I used to solder them all but went to using crimpers because there faster and less chance of bad solder conections. your going to need MAP gas torch like this Bernzomatic TS4000KC Trigger Start Torch Kit-336634 - The Home Depot to get them hot enough for a good solder joint.
Copper is the way to go IMO.Those look like they will be just fine.I just use the concrete floor, a good small sledge hammer and a good hollow punch with 3-4 punches on ea side and heat shrink it. I've never had a connection come loose.
Thanks guys, a co worker used compete in audio competitions and said he recommended soldering and said he would do it for me, just need to order the stuff for him. Ill do some more digging around.
is 3/8" the standard size?
No problem and good luck with your soldering ! did you get some 3/4 heat shrink tubing to cover them whey your done ? looks nice and seals it up so no corrosion can start. If your only talking one or two lugs soldering is not to bad provided you have the right torch but you dont really gain anything over crimping and its way faster and easier. But to each his own. I just got alot lugs on mine so gave up soldering long ago.
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
6
725
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
9
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Ballistic89
Ballistic89
Las Vegas, NV
big scott
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
